| Message |
good solution, why didnt you leave it like that? Dont give people bad advice, what if hes on 91 or somethin, he will detonate like an ass on a hot day...
 -"Chains baby, chains.......Z will grip like a champ. (n/m) - Wolf [Pittsburgh] 14:56:58 05/10/00" How to Check Turbos: "1st remove exhaust and pre-cats. Then fire that mother up, rev it to at least 5000 rpm and then stick your finger into the hole on the back of the turbo. If the turbine grinds your finger down, then your turbo is working. If your finger gets ground off farther than the second knuckle, then your turbos are good for at least another 60k miles! Don't forget to check both sides." -I am Z-ing Double -"The world's two biggest mysteries: The meaning of life and fitting the Howe radiator into the Z..." -Seedyrom, circa 2000 |
